Tire pressure. ?
Go with the tire pressure that is annotated on the placard on the pillar inside your driver's door or in your owner's manual, typically around 33-35 psi.
The rating molded on the tire itself is the maximum pressure the tire is rated for.
btw: going with a higher pressure may slightly increase your gas mileage, but at the expense of uneven tread wear and poor handling.
