16" Winter Wheels for Allroad
I have an '02 allroad 2.7T and have been having the same problem. I have the two piece 17" on them now which is 17x7.5 and 25mm offset. Since you will be decreasing the wheel size and width (since you want 7" for winter), the offset will change as well. The closest your going to get is 35mm (32mm might exist, not sure) without needing spacers and longer lugs. I currently have A6 wheels for winter that are 16x8 with a 35mm offset but obviously the width sucks in the snow. This is all information I've come up with since my search online as come up dry for information. Hope it helps.
I have an '02 S6 Avant and I am also looking for a set of 16" wheels to put on for the winter seeing that the only tires available in the 17" for that car are not all-season.
I was thinking a set of 16" A6 factory wheels, but not sure they will clear the calipers. Anyone had any luck getting something factory work?
paulywalnuts446
14
02-23-2020 05:20 PM
wpg2.0T
10-29-2011 01:55 PM
SharpHID
09-29-2009 04:51 AM
