VagCom- No Response from controller
Hi guys, I'm trying to get into the 01 Engine Control Module in VagCom 409-1 but every time I try I get an error message that says:
"No Response from Controller!"
I've already got the (alpha-bid) cable connected with all drivers downloaded and the correct COM Port being referenced between VagCom and the Device Manager with Vag saying successful every time I test it. I also tried with version 3112 with the same exact results.
Help please???
Help please???
It's the eBay cable... And this is the second time I'm using it in the car, the first time it worked no problems, I was able to check for codes (as far as the shareware license allowed) without a problem. However, today it just isn't working, can't even check for codes again... I don't get it.
Well the little green light is on... And it's showing up on my Hardware Manager... I've also handled it with care... I read somewhere that changing the "Baud" parameter can help... Ever heard of this? What values should I try?
does vagcom recognize the cable when you go into the setup tab and click detect?
if no- you should google "how to change com port number"
if vagcom isnt recognizing the car- is your ABS light on? do you have an aftermarket radio?
Yes it does test successfully and the COM Port is the correct one between VAG and my computer...
My ABS Light IS on (been on for a long time)... Does this affect the problem?
UPDATE: I've been sitting out here in the car just messing around and this thing gets more and more strange... For some reason I can get into the 56-Radio Control Module all right... Why the heck can't I get into the engine? I would understand that my car might not have every single module that VAG supports, but I'm sure it's got a 01-Engine... lol
Please help guys, I really need to get in here to clear and diagnose some problems so I can have a car once more.
