VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
vagcom and lemmiwinks
Old 09-10-2007 | 01:37 PM
ooantipostoo's Avatar
Default vagcom and lemmiwinks
Where canI pick up lemmiwinks and about how much does it cost. I was looking on REVO's site and couldnt seem to locate it. Thanks guys!
Old 09-10-2007 | 01:41 PM
cincyTT's Avatar
I'm make believe
Default RE: vagcom and lemmiwinks
Its free, download unitronics better version here
Old 09-10-2007 | 01:49 PM
So sick thanks a bunch cincy. I have a snapon computer with vagcom this should work right? Or do i need to run it off a computer? With the diode in also could i tune it properly to almost be the same as a chip? Do i have full capabilities to changing the computer as i seem fit?
Old 09-10-2007 | 01:51 PM
cincyTT's Avatar
I'm make believe
Most likey the computer. You can try the snap-on first. You will have more control, but far from total control of the ecu. But you will be able to make it run better than you are currently
Old 09-10-2007 | 01:53 PM
Ok, well im looking for a fully programmable so Im not suckered into buying over priced chips.
Old 09-10-2007 | 02:03 PM
cincyTT's Avatar
I'm make believe
Than your going to need a standalone engine management, and thats going to cost you over a grand, not to mention tuning. Also its very hard to have it pass emissions with a SEM
Old 09-10-2007 | 02:52 PM
Sorry forgot to ask where can i get a USB vagcom for our cars.
Old 09-10-2007 | 08:00 PM
cincyTT's Avatar
I'm make believe
ross-tech.com
Old 09-10-2007 | 09:04 PM
MeanAudiA6's Avatar
or ebay like where i got mine....workd good...and just buy the 100 license from rosstech.. will save you around $100 if not more
Old 09-27-2007 | 04:59 AM
BARRY's Avatar
ebay cable works, lemmiwinks works fine with my ebay cable. just make sure you select the correct com port when connecting.
vag-com only works in shareware version with my usb obd2 cable.
