VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
vagcom decoding help
Old 07-23-2009 | 08:37 PM
juxsa's Avatar
Default vagcom decoding help
any one want to tell me whats up with these vag com codes and what I can do to fix it?
I figure the ones about the car alarm are not important
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 M
Component: 1.8L R4/5VT G 0003
Coding: 16201
Shop #: WSC 79156
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18015 - Vehicle Speed Sensor -- Malfunction Indication from Instrument Cluster
P1607 -- 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02244
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16204
Shop #: WSC 06435
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
4 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 06435
No fault code found.
End -------------------------------------------------------
Old 07-23-2009 | 09:54 PM
TeeterTawter's Avatar
address 35 and address 45 are nothing to worry about, delete them, and see which ones return after a few days after another scan
Old 07-23-2009 | 10:29 PM
juxsa's Avatar
what about the other ones?
Old 07-24-2009 | 02:13 AM
brrman's Avatar
P1607 -- 35-00 - -
P1606 - 35-00 - -
These indicate you probably have an ABS speed sensor ring broken, or your ABS module is on the way out.
This is likely a result of another code and is nothing.
Like TeeterTawter said, first thing to do is clear ALL the codes. Then drive for a couple days to see which ones come back.
Old 07-24-2009 | 01:11 PM
juxsa's Avatar
i do have the abs module out. Plan on putting it back in the next few days.
ECS Tuning
11-29-2021 07:46 PM
ECS Tuning
01-07-2013 06:29 PM
ECS Tuning
B7 Models
01-07-2013 06:28 PM
ECS Tuning
B8 Models
01-07-2013 06:28 PM
S4sweeteeteeRS
06-10-2005 03:46 AM
