VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
HELP! First VagCom Scan Results. . .
Old 09-25-2007 | 05:17 PM
jshil's Avatar
Default HELP! First VagCom Scan Results. . .
I just got my TT two months ago and this is my first scan with my new VagCom Cable (Thanks Alpha-bid). If anyone has any insight on any of my issues, I'd love the advice. Im not concerned with the Centr. Locks Codes, but I posted the entire scan none the less. Regarding the P1128 Code, I have cleaned the MAF (and changed the air filter while i was in there) but no luck. The Check Engine Light has been on steady for a lil while now and the ESP light comes on intermittently (its on more than its off). Thanks in advance for your help!
2001 Audi TT Quattro Coupe
Auto Scan[/align]
VAG-COM Version: Release 409.1-S
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01236
TRUWT28N411016992 AUZ5Z0Y9043156
2 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-10 - Electric Circuit Failure - Intermittent
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D52
Coding: 07244
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
3 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
Address 45: Inter. Monitor
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
Address 56: Radio
Controller: 8N0 035 186 A
Component: Radio D05
Coding: 00517
Shop #: WSC 01236
End --------------------------------------------------------------------------------------------------
AWD
Control Module Part Number: 02D 900 554 B
Component and/or Version: HALDEX LSC ECC 0006
Software Coding:
Work Shop Code:
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00526 - Brake Light Switch-F
27-10 - Implausible Signal – Intermittent
Old 09-25-2007 | 06:05 PM
achTTung's Avatar
Default RE: HELP! First VagCom Scan Results. . .
replace the acceleration sensor, I think that fixes the ESP issue, and I don't think its expensive, someone else will have to add to that.
I had the internal memory module failure on my haldex, replaced the haldex controller with the 'blue controller'. this unfortunately isn't cheap. Got mine on sale, $750, but on the upside, the car handles a little better accelerating thru turns.
Engine codes I'm not sure on...
Lock codes, total bullshit. You'll get stuff like that anytime the alarm is set off. Lock the doors with the windows down, and walk to close to the car, and you'll end up with those codes.
Brake light switch is under your dash, they get dirty and quit working, most times you can clean it and it'll fix it.
Old 09-25-2007 | 06:08 PM
MeanAudiA6's Avatar
search for my thread on ESP fix on the forum its around 140 bucks for the sensor from worldimpex.com and is very easy to replace. located under the steering wheel column
Old 09-25-2007 | 08:06 PM
jshil's Avatar
thanks for the quick replies. i also forgot to add that i cleaned the fuel injectors, incase anyone has anything to add about the engine codes. ill get on the lateral accel. sensor right away if thats gonna take one more light off my dash :-) As for the AWD, are we saying that the module definitely needs to be replaced?
Old 09-25-2007 | 08:36 PM
achTTung's Avatar
Thats the only fix I see, its solid state electronics, not like you can go in and tweak something
Old 09-25-2007 | 08:57 PM
jshil's Avatar
got it, maybe i can get the work done under my extended warranty (fingers crossed). As for the engine codes, im thinkin MAF or O2 sensors - does anyone know if the MAF recall extends to second owners?
Old 09-26-2007 | 12:50 AM
themysteryman83's Avatar
jshil, check for airleaks in the vacuum lines and intake tubes. If you're getting hesitation or rough idle then it wouldcoincide withthe lean code.
to check the maf just disconnect it and see if the car runs better. if so then bad maf, if runsthe same then maf is fine.
the second code maybe the secondary air pump, but just a guess though. Maybe a leak in the hoses somewhere?
Old 09-26-2007 | 10:16 AM
jshil's Avatar
thanks, im gonna d/c the maf. Theres no rough idle, but I'll check if it runs any better unplugged, then ill check for leaks. I read somewhere else about removing the secondary air intake. what exactly would that do for me?
Old 09-28-2007 | 09:19 PM
jshil's Avatar
ok, so i d/c'd the MAF and Im thinkin, 'I hope I can tell the difference if this really is the problem'.....WOW! what a difference....so, anyone have a suggestion on the best place to pick one up or which isthe best aftermarket replacement? And another question, with my AWD having issues, is my car still gettin a close-to-normal amounts of torque to the back wheels or am i drivin a FWD til i get it fixed?
Old 09-28-2007 | 11:51 PM
ORIGINAL: jshil
Iirc, it's only an 80/20 ratio to begin with. So that's 80% to the front wheels and 20% to the rearonly when it needs it. What was the difference that you noticed between unplugged and plugged?
Quick Reply: HELP! First VagCom Scan Results. . .
