Squeaking Suspension Help
I'm about to have my Left Front Upper Control Arms with BJ & Bushing replaced tomorrow. I experienced all the noises talked about in this forum. I have a 03 A4' 1.8T. I'm curious to see how it turns out. The place i'm taking my car to is a German Car repair specialist and the total estimate is $470, so hopefully the noises don't come back. !
Got Upper Arms Replaced
As a follow up to my original post, I just had my upper arms and associated parts replaced. Of course, the noise didn't completely go away (although it seems to have reduced). Now the shop is telling me that I have to replace the lower arms as well. Since the lower arms are the ones bearing most of the weight !!! I'm down $417 from the first repair and am looking at a similar windfall next week. Does anyone have pictures of what worn out Lower Control arms look like? Thanks.
I bought this set, killer deal!
http://www.ecstuning.com/Audi-B5_A4-...sion/ES337518/
Also, my car squeaks as well but it turned out to be a broken rear left spring.
Had the same problem before... Frequent and progressing squeaking sound in the front end when turning the wheel even when I drive on a straight road then hit a bump.. I thought it was the steering rack but as I’ve read from Audi repair that the symptoms leads to the tie rod bushings.. I was able to find the fix there.. Slitting a hole in the rubber boot and shooting lube on it.. But I guess buying a new tie rods for 70 bucks is an option too..
Squeaky noise
first post for me...
Changed the front shocks and springs on my A6 2006 2.4 petrol and now i have a weird squeaking noise coming from the front drivers side wheel... when i turn the steering. I think is the shocks, i will check it and i will let you guys know...
The problem was the the shock absorbers.
The problem was the the shock absorbers. (the bushes) At the top of the shock absorbers, have a bearing or bush which rotate, allowing the wheel to be steered. Thank god I found the problem, because one of the garage told me is the CV joint.
#18
I understand that they aren't separable.
#20
Hi ...here is some info for you
Audi Allroad air suspension system consists of air bags that surround the shock absorbers instead of conventional coil springs. The adjustable Allroad air bag compression is managed by a control module and air compressor that are delivered via air lines. This type of Audi Allroad suspension set-up allows for variable suspension feel and height.
signage
Hoarding In U.P
signage
Hoarding In U.P
