Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
need help noise comming from front left side
Old 05-11-2006 | 11:40 PM
audi90s's Avatar
Default need help noise comming from front left side
hello plz need help when i drive my car strange noise come from front left side.i lift the car i moved the tire left and right so there was a play and when i do up and down its ok.2day i took the car to the garage the guy said cv boot is tornup it need to be replace and cv joint too but i dont think that its a cv joint cuz if the cv joint is not good condition it should make noise in turning but when i turn my car there is no noise.when i drive the car straight it make tick tick noise when i press half brake it make more noise when i press little hard brake the noise goes away so plz can anyone tell what is it?do i need to change cv joint,tie rod end and ball joint?my car is audi 90 1993 front wheel drive.
Old 05-12-2006 | 04:20 AM
A4 the Quattro's Avatar
Default RE: need help noise comming from front left side
if its a squeeling noise.. could be wheel bearing
Old 05-12-2006 | 09:18 AM
audi90s's Avatar
Hi
Thanks for reply i jack up the car then run the engine i saw that the left front side wheel is bumping but the alloys are straight i mean no dent no accdented there is noise like tuck tuck and play do u still think that its a barring?i took to the mechanic but he was talking stupid was saying its ball joint,tie rod end, cv joint and break cant be all when i moved the tire left and right there was the play middle of tie rod assambly but i am not sure what is it.and dont know where that nois comming from but i am sure comming from front left disk so plz give me sum idea what should i check what it could be.
Thanks
Old 05-21-2006 | 07:17 AM
audi90s's Avatar
hello need help dont know from where the noise comming from plz help me.
Thanks
Old 11-09-2006 | 03:29 PM
dxl2749's Avatar
did you check the transmission mount brackets or motor mount brackets?
Old 11-09-2006 | 06:25 PM
chrisaudi's Avatar
jack the car up grap the tire top n bottom and see if u can move the wheel is be the bearing
Old 11-10-2006 | 08:49 PM
TommyL's Avatar
ORIGINAL: A4 the Quattro
I second that, sounds like a wheel bearing
Old 09-30-2007 | 10:30 PM
intrique420's Avatar
Hi.
I have avibration when I turn left around a left-hand bend. Sometimes I hear a noise, like a rub. It only does it when turning left. It will NOT do it when turning sharp. Also, if I jerk my steering wheel left and right, I hear a glunk under the car.
C4 A6Q 2.8
any ideas??>
as for your noise, I doubt it is the CV joint b/c it would most likely make noise while turning. Wheel bearings sometimes shut up when braking under load, so light braking would make them noisier.
Old 10-11-2007 | 07:03 PM
DirtyDaego's Avatar
intrique420, i would agree with the wheel bearing being the probable cause
vlado182000
04-12-2010 04:44 AM
2000turbo
01-21-2010 01:12 PM
shockedimpy
12-21-2006 02:58 AM
zlaninomma
02-07-2006 02:24 PM
ryan
03-06-2005 12:48 PM
