Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Eibach/Eibach or Eibach/Koni Yellow
Old 08-18-2008 | 03:46 PM
MacAudi4's Avatar
Default Eibach/Eibach or Eibach/Koni Yellow
Hi all,
I am looking to upgrade suspension on a 2003 A6 3.0 FWD. Which is a better combo:
- Eibach Springs with Eibach shocks (the Pro System) or
- Eibach Springs with Koni yellow shocks.
It is my daily driver car and I just want a firmer suspension with better handling and less roll/squatting/diving, but not too harsh.
For that matter, could I get a significantly better ride by just putting on Koni FSDs with the stock springs?
I've never tried aftermarket suspension upgrades before, so any advice would help. Thanks!
Old 08-25-2008 | 08:17 PM
Jeepersinco's Avatar
Default Eibach
I just replaced the stock non-sport suspension on my 01 A6 2.7t with the Eibach kit (coils and shocks) yesterday. I also added RS6 sway bars. My first impression is that it doesn't ride as well as I had hoped for. It's not that harsh but it seems to float up and down over dips and bumps more than I would like, and more than the stock suspension. I have not got a chance to wring it out yet but I'm hoping for more of a positive change in body roll.
I don't have experiance with the other two set ups but thought you might want to hear abou the Eibach set up.
Jim
Old 08-26-2008 | 09:51 PM
MacAudi4's Avatar
Default Hope it settles out to a better ride for you
Thanks for the feedback. I ordered the Eibach system kit a few days ago so I guess I'm committed for better or worse. I'll let you know what I think of the set up in a couple of weeks. I can't imagine it will be worse than my current setup of OEM non-sport springs and blown shocks.
Frank
Old 08-29-2008 | 01:52 PM
myxyzxo's Avatar
SoCal Crew Member
~sigh~. Eibach Pro Kit is my biggest regret. I have them installed on my 225t and you can't even notice it is lowered. Manufacture says 1.5" drop all around (I didn't get that, more like .5"). If anything, when I measured the space from wheel to body (from the rear). I have less of a gap then my fronts. It's a bad stance. Only good thing is the ride is still smooth.
You can see the Stance on my pic below.
Old 09-05-2008 | 01:29 AM
Default Eibach impressions
I had a chance to take out my Eibach equiped A6 over the holiday weekend. Drove from Vail down to Aspen and back. It does corner very well and I still wouldn't consider it harsh. With the RS6 swaybars it has virtually no body roll and it a lot of fun. I've owned a C4 Vette and a moded Miata and for a sedan it handles quite well.
Jim
MyE46HerA6
14
01-29-2009 01:57 PM
Phildo
03-17-2008 07:30 PM
junshannon
03-04-2008 01:31 PM
justincr250
03-28-2007 02:55 AM
advocates
01-29-2007 06:55 PM
