Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Control arm question
Old 08-05-2006 | 04:50 PM
iowaboostin's Avatar
Default Control arm question
Hey all.. my '99 A4 1.8tq has the infamous creaking suspension, I've done my searching and found it's most likely the upper control arms. I'm looking on ecstuning.com and finding that the OE upper control arm (straight) are $94 including the hardware and the OE 'Febi' upper control arms are only $74 but w/o the nuts/bolts. My question is, are the nuts/bolts on my Audi needing to be replaced or can I reuse them? ECStuning is selling a hardware kit for $15 because they're most likely damaged when removing them.. is that true or just a scheme to make some more money? Thanks for any input!
Old 08-06-2006 | 09:23 PM
Mike@PureMS's Avatar
Default RE: Control arm question
Consider investing in a full control arm kit like our Febi-Bilstein kit. It has all 8 arms, sway bar links, and tie rod ends. It also includes all necessary nuts and bolts.
Old 08-08-2006 | 11:20 AM
dafrazi's Avatar
You will probably destroy the pinch bolt when you remove it. So yes, buy the hardware kit.
elduderino200
07-01-2014 12:27 AM
edwin2424
03-13-2014 04:33 PM
shortyxc
09-23-2009 12:35 AM
PTEmbree
04-30-2009 01:21 AM
kickasS4
10-29-2007 10:49 PM
Quick Reply: Control arm question
