Sights N Sounds Upload and Post Video and Sound clips here. This forum is for video's pertaining to Audis, Racing (Street/Strip), Interviews, and Off Topic.
Hooking up the pre-wired Satellite Radio for 2008 A4
Old 12-30-2009 | 05:35 PM
lam0nt's Avatar
Default Hooking up the pre-wired Satellite Radio for 2008 A4
My 2008 A4 is pre-wired for Satellite radio, there's a Satellite button on the radio and I have found the wires in the trunk that are meant to connect to the Satellite receiver, And I have found this GREAT step by step process to hook it up with pictures at http://www.audiworld.com/tech/elec115.shtml HOWEVER, in all of the other chatter about this topic on earlier models, there are 4 plugs encased in foam that will allow you to plug and play. I ONLY HAVE 3! That's all I see anyway. Is the 4th hidden??
Two are 8-pin connectors (one straight, one stacked) and the other is the green plug. In everything else I've looked at, there should be a brownish reddish plug that looks just like the green one. Where is THAT plug??
I found an XM receiver from a 2006 A4 that would hook up perfectly but it needs that extra plug (I'm assuming). Is this some sort of trick from Audi to keep you paying $650 to have it installed at the factory? HELP HELP HELP!
Thanks!
Old 02-05-2010 | 07:21 PM
lam0nt's Avatar
Default Anyone?
Anyone new to the forum that has any idea about this?
Old 02-27-2010 | 11:03 PM
matta38p's Avatar
I have been researching satellite for my 2007 A3. It seems that there was a change mid 2007 for the sat receivers. I'm still trying to find the correct part # for the newer receiver. Seems all the cheap units on ebay are the older model.
Call these guys and give them your VIN. Maybe they will have unit that will work. Probabbly will be Sirius and not XM.
bkuehl
04-16-2013 12:14 PM
Patroller92
10-16-2010 02:34 PM
robpfei
03-01-2008 07:28 AM
shaady1727
02-20-2007 06:13 PM
