What plugs is everyone using?
I was just wonderin what kinda spark plugs is everyone using? And if they noticed a difference over stock? Im chipped so I'd like to hear from some people that are also
RE: What plugs is everyone using?
I don't know, cuase I might be a bit biased right now, but I just installed some Denso Iridums and they're awesome! Pulls a lot stronger now and all the roughness/hesitation is all smoothed out (granted my old plugs were probably a fouled, so there's that to consider). I'll let you know how the mileage and stuff goes after a few thousand...
I just ordered some NGK BKR7E..I was doing some reading on audigeeks.com and they made a very good point about copper plugs. they are the best conductor and the dispell heat the fastest. They dont last for **** but for they are cheap, about 2 something a plug..ill have to change them in 3000 or so miles though..Ill let you all know how they go
ORIGINAL: Brandon2000s4
So it's really six in one hand &half a dozen in the other... I don't think anbody knows exactly how much of a difference (if any) in HP/TQ/MPG one would get from a Copper plug over an Iridium (seeing as Irdium has better characteristics than Platinum in this game: http://www.sparkplugs.com/pdfs/iri.pdf). Even if the was, the question them remains for how long will Copper outperform?
The bottom line is: Techonology and the market are definitely moving in the other direction using various new alloys, versus different versions of copper. This tells you that conductivity, although playing a major role, is not the only variable in the equation. Someone said it best in that: "If they really wanted to make the best plug, it ought to be silver"!
ORIGINAL: 2k S4
Just use stock. Yes others will work. But there seams to be the lowest problems with stock plugs.
Arent u ment to run 1 step cooler plug like the BKR7E if u modded?
