Warped Rotors cause vibration when not braking?
if you think it is the rear try pulling up the e brake while going down the road. if it shakes more it is the rear rotors. usually shaking in the seat is rear and shaking in the steering wheel is the front.
Check the center driveshaft bearing like so
http://www.blauparts.com/audi/audi_d....shtml#trouble
Keep us posted with the what the solution is.
Hmmm, Jibberjive you make a good possibility. I had my dad ride in the back seat to try and see where the vibration was coming from and he said it felt like it was underneath the car. Where the driveshaft would be. I also could hear a faint high pitched noise when driving slow (5mph) by trees or other walls. I'll keep everyone posted.
had a Bentley mechanic at my dealership take a look at my car today and we noticed that a belt had slipped on my tire. I'm hoping its the solution to my problem. Hopefully in an hour or so I'll know.
#18
hopefully your diff is ok. mine had a similar issue and it turned out that the lower profile tire on the front i was running, being 9mm smaller in overall diameter then the rear tire caused the awd to freak out and would vibrate in the seat. put my other front tires back on and im good. took awhile to figure out. we thought all the possibilities like you are.
btw
your car looks badass
btw
#19
Well I went brain dead for a lil bit and forgot that when I changed wheels I couldn't get the fronts to fit. I swapped with my fathers A4 wheels and found out that they didn't fit over the calipers. Blond moment I guess, even though I'm no where near blond. I put my spare on and drove it around and the problem was fixed. Crappy thing was that my spare was directional so I had to swap sides. Now I feel a very very faint vibration from the spare tire. So I'm thinking its either A) not correctly balanced or B) its a little smaller than my other tires. I've got a new tire coming tomorrow so it wont be on long.
And xxbmxlsxx
Thanks, I'm workin' on keeping her clean but tastefully modded. I was set back a few weeks ago though. A deer seriously just ran into the side of my car as I was creeping at 5mph. Dented the driver's fender and driver's door beyond repair. Also broke my stinking mirror. Then a week later my father scraped into my front bumper and he offered to pay for the repairs. I'm doing all the work myself so its taking some time to fix. I'm going to go ahead and do the RS4 bumper mod before I paint everything.
And yea, I'm sort of glad it ended up being the tire because its a lot cheaper than other things that could have gone wrong.
And xxbmxlsxx
#20
I wanted to add this
