Stage2 running 6sec FATS, whats wrong?
Is this right, Ive done atleast 3 good runs(freeware-VAG). APR91, no spare or muffler+rez, low tank, Im 150lbs. outside temp is cool. Perhaps someone could point me in the right direction as far as what to look for with uni/lemmi/vag. My S4 will never be faster than yours, so you have nothing to worry about.(only handful of S4s in 50 mile rad.) Thanks and have a good night.
You need to post more information than that for us to help you. take a look at your ignition timing angle, boost leak check it. What chip do you have? Look at your ignition timing retardation. There is a lot that needs to be seen before anything can be determined.
Is it my 91oct APR chip? It seems to lose it up top. but I never hear any leaking. My lame *** is sitting here with freeware, for now, so Im limited on what blocks I can log.
This is the first car I mentioned. It is on 2.5 DP custom exhaust, meth injection and tune. That is it. This pull was on a tune not meant for meth and with 100 unleaded in the tank (mixed with 93 so it wasn't quite that high). Enjoy!
MarkPv11161_30040_image001.gif?t=1259786765
MarkPv11161_30040_image007.gif?t=1259786804
MarkPv11161_30040_image008.gif?t=1259786860
MarkPv11161_30040_image009.gif?t=1259786887
MarkPv11161_30040_image011.gif?t=1259786997
MarkPv11161_30040_image015.gif?t=1259787013
MarkPv11161_30040_image018.gif?t=1259787029
MarkPv11161_30040_image026.gif?t=1259787067
MarkPv11161_30040_image032.gif?t=1259787110
MarkPv11161_30040_image033.gif?t=1259787137
That helps, thanks. But what tuning was done on it? Otherwise mentioned, its stock?
My timing says BTDC but your numbers are + in the same amount. The engine load is much higher than mine.
I pulled up to 3deg of timing(-1.5, log 3 runs, -1.5, log 3 runs), But my CFs still hit 9s. I gotta go, so I'll log more while Im out and get back.
Ahh! I see. Its too bad Vast is too far away from me, but that wont stop me from exchanging my pipes for piggies next year.
My FATS are still 5.9. I added +1.5 deg timing, to see if I could measure anything, and logged 3 runs. Then my CFs went to 12s and my FATS went up .25secs. I cant help but think I cant pull anymore timing and that the car is pulling all it can due to the 91oct. Some day I'll test this by dumping some xylene and logging. DUH! I noticed my logs would sometimes say ATDC or BTDC. A funny thing too is I cant Pause Vag-com if my rpm is to high. Any way, its just a matter of time......and money.
