Smell after tire spin?
Good good! Im almost sure now its the clutch slipping ever so slightly due to water splashing onto it....I only get the smell when the roads wet and I try to spin the tires. I have new gaskets and know burnt oil smell. Oh well, if I go stage 3 I'll most likely have to upgrade the clutch.....again. Or does an RS4 clutch handle stage 3?
if it won't handle stage 2 which you have now do you actually think it will handle more power?? oh and by the way the clutch is shielded from water... ud have to drive through a puddle that came half way up your doors for water to get in there... you just treated you clutch like **** so its treatin you like ****... you prolly didn't break it in right... we all know how you drive.....
I'm going to go with that smell being you tires. I notice something like this during a snow storm and I was tring to back into my parking spot. I'm very sure the tires were spinning on wet/snowy pavement but the smell did not smell like burning tires. But after I got parked I went to each tire and for sure it was coming from the tires. I think it's a mix of water vapors and burning tires that gives off a smell similar to burning up a clutch. We are all used to the smell of burn outs on dry pavement which is likely a different smell. I would not worry about it unless you got little tread on your tires.
seanpawn
02-10-2009 02:26 PM
