Short Throw Shifter Opinions
I checked the posts for opinions on a short throw shifter for a 2002 S4 but didn't find what I was looking for. Basically I don't want anything too tight or notchy. Looking for something smooth that will just get rid of the slop. JHM seems to fall into the notchy category. B&M gets mixed reviews. Hypershift seems to get good reviews. Others? Suggestions?
RE: Short Throw Shifter Opinions
i did the ToyGuy short shifter DIY this weekend, and its pretty smooth if you get the linkage configured correctly, but still a little sloppy.. i even did the zip tie mod
ORIGINAL: readimag
i love the JHM it is kind of nochy but that is also could be cause you need to change your tranny fluid. i know after i did that buttery smooth
I like my JHM alot, you found a noticeable difference after changing your transmission fluid? Maybe i should try that too is it hard to do yourself?
I'm very happy with my B & M - but would likely consider the JHM if I was doing it now. B & M might be a little notchy - but not at all bad and the ss improvement is well worth it.
