shifter question
shifter question
Maybe this has already been addressed somewhere, but I can't find it. Do all B5 S4s have somewhat of a rigid shifting feel? I feel like i have to force the shifter sometimes into 1st, 2nd, 3rd. Would a short shifter have a better feel, and a smoother, faster shift? Does anyone else have issues like this with the stock shifter?
RE: shifter question
force as in likea more gated shifter like feel, cause thats true. Or force as in like your having a hard time getting it into gear, I presume your talking about my first answer. Our gear box is none too sloppy at all.
To me that sounds like something is wrong or thesyncros are wearingetc...depending on how hard you need to force the gears that is. If there are tranny issues, changing to a short shifter would be unlikely to help your problem, unless it's a bushing or similar part included in the install. The short shifter might make it slightlyharder to get into gearactually.
You might be better off spending the money on changing the trans. fluid first and see if it helps the feel.
With all that said, the S4's transmission is known for being a little notchy and having somewhat of a long throw...so basically if it feels like something is notright trygetting the fluid changed.
yeah ive noticed the more notchy feel too
i feel like 2nd isnt straight down and if you try it almost gets hooked on something
its more like down and a little to the right
it took some getting used to but now ive got it smooth
ORIGINAL: washyourrhands
ORIGINAL: HP Addict
perfect description of how my shifter used to feel. The JHM shifter, DTS, and snub mount made it much nicer to shift. Im going to change my transmission fluid next iv heard form alot of people that it helps
whats the full setup you guys have
i dont really know much about short shifters and whatnot
what company should i buy it from?
