Seafoam...
Old 10-17-2009 | 08:57 PM
Mott Power's Avatar
Default Seafoam...
... is awesome. My engine has about 100k on it and I spat out so much carbon build up; it runs so much smoother and idles better. I put 1/3 of it in the fuel tank and 1/3 in a cup and had a vacuum hose suck it in to the manifold while it idled.
I highly recommend this stuff if you've got over 100k on your motor. Link to the DIY:
http://www.audi-forums.com/b5-forum/...4-seafoam.html
Old 10-18-2009 | 01:43 AM
bottlecap's Avatar
damn i just got my oil changed yesterday...next time for sure though. do you have a vag-com to clear your code(if any) or did it just clear itself? i dont have a vag reader so im unsure of doing this
Old 10-18-2009 | 01:48 AM
Mott Power's Avatar
I did have a few codes pop up and cleared them with my VAG reader, so yeah that would be annoying if you don't have one.
I didn't put any in the oil and I saved some for when I do change it next. You can still do what I did using just 2/3rds of the bottle only in the Vacuum lines and Fuel Tank.
Old 10-18-2009 | 02:00 AM
bottlecap's Avatar
maybe ill try it later..i dont want to sell my car with a check engine light on too..not good for business
Old 10-19-2009 | 11:15 AM
drev500@aol.com's Avatar
The codes are uaually for the O2 sensors due to a lean reading. Just disconnect the negative wire off the battery for 10 mins then hook it back up and it will clear the code.
Old 10-19-2009 | 01:14 PM
bottlecap's Avatar
word..good thing i have to day off to tinker with my car
Old 10-19-2009 | 11:48 PM
DavidgotanAUDI's Avatar
yeah Seafoam is the best i have used it in all of my cars even the drag car the day before I take it to the track but I use all of it in the vacuume line dont run it in the tank....dont know how well it would go with 110 race gas
Old 10-20-2009 | 07:46 PM
With the use of Seafoam and 110 you might have some extremely hot EGT's so I'd be cautious with it. Maybe try asking Seafoam directly
Old 10-21-2009 | 08:42 PM
mys4.org's Avatar
I did the Seafoam treatment on my S4 in August and man did it put up a smoke show. My entire neighborhood was all smoked over. Fun times. The most noticeable thing was that my engine revs much better. I would not recommend put this stuff in the oil.
Old 10-22-2009 | 12:12 AM
bottlecap's Avatar
how long did it take to burn of and stop smoking?
Quick Reply: Seafoam...
