S4 Runs 10.67 @ 132.73. Stock Motor, Pump Gas, Bolt Ons, 21psi!
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
ethanol.. and no you cant. i mean .. to run good no.. i think that you have to have a bigger fuel pump cause you go through a lot more fuel that way as well...now as to whether or not you can just put pump gas in .. i dont think so but im not 100% sure..
yeah. im pretty sure marc has bigger turbos.. still. its k04..i could just imagine with the TiAL kit or even RS6's with his weight reduction would be ridiculous... i wish he had video up of these runs... it would almost be unbelievable .. the wot box helps but still weight reduction is prollly the key..
Doms best run is a 10.51 @ 137 in his GT28 car with full interior. Now that is seriously impressive
#19
![Wink](https://www.audiforums.com/forum/images/icons/icon12.gif)
Just to recap for those folks who don't know, this is a 2000 Audi S4 with a bone stock 2.7T engine. Stock heads, stock cams, stock pistons and rods, stock exhaust manifolds, stock electronics, stock ignition, stock (decatted) downpipes, etc. The ONLY aftermarket engine related/power adding mods that it has are the 60lb injectors, 85mm MAF, AEM filter, and Ebay FMIC. Everything else is either factory original or OEM RS4. Fuel being used is E85 which is available at the pump only 6 miles away from my house. Boost spikes to 25-26psi and is holding only 21psi at redline.
#20
it says "bone stock 2.7t engine".. nothing about stock turbos.. "factory original or OEM RS4".. marc has been around forever with his blue beast.. i think everyone has known for a while hes got pjk04's in there...
