S4 issues.... never ending
Old 11-19-2009 | 01:00 PM
dnasians's Avatar
Default S4 issues.... never ending
ok, so i have a 01 s4 and here are the issues. im looking forward to the online diagnostics.
only engine mods are bov's
1) my car will jerk at low rpm occasionally (like a bucking horse), but when im driving hard, its fine.
2) one day i was driving on the freeway, the ECS light and the ABS light turned on, and the car would not provide any power. The motor was still running, but when i press on the accelerator, nothing would happen. when i turn off the car and turn it back on, it resumes on driving fine.
3) during idle, it idles between 1000-1100rpm... really high, and it throws that CEL out.
CODES:
p1128 maf sensor
p1130 maf sensor
p1136 maf sensor
p1138 maf sensor
p0507 high idle
p0102 maf or vaf a circuit low input
I NEED HELP!!!!
Old 11-19-2009 | 03:06 PM
Mott Power's Avatar
it'd be nice to see the codes.
you don't have anything done to the car other than bov's? i would think something along the lines of a bad O2 sensor or MAF
Old 11-19-2009 | 04:28 PM
drev500@aol.com's Avatar
BOV'S?????? I hope not becuase that could reason for codes. Please Please Please get diverter valves not BOV's.
Old 11-19-2009 | 06:24 PM
dnasians's Avatar
i know s4 owners hate to see one with bov's but i believe i did it the right way... we'll see soon enough lol, getting codes before tonight
Old 11-19-2009 | 10:13 PM
Mott Power's Avatar
It could very well be the BOV's, especially if you don't have a tune for them and have them spaced/sprung correctly. They could be opening partially at a certain psi and releasing boost, which could cause the car to throw codes and maybe even go into limp mode.
You need to have a proper tune when running BOV's and have them correctly mechanically tuned for the boost/vacuum.
Old 11-20-2009 | 12:21 AM
dnasians's Avatar
i dont think its the bov's but i could be wrong, i just put up codes HELP
Old 11-20-2009 | 03:06 AM
Mott Power's Avatar
hah, common now... you don't know what those codes are telling you to replace?
Old 11-20-2009 | 09:28 AM
dnasians's Avatar
i mean, yeah i KNOW the maf is bad, but could it be causing ALL those issues?
im soaking it in 91% alcohol right now.
Old 11-20-2009 | 12:30 PM
Mott Power's Avatar
eh, something else 'could' be causing that issue, but i doubt it. a faulty MAF would cause all those problems.
Old 11-20-2009 | 06:24 PM
bigern45's Avatar
could be a maf.. but bov's might give you a maf code as well.. not all of the air metered is going into the system.. so could look like a faulty maf.. but might also give you a rich code.. i guess make sure you have proper diverter valves and put a new maf on and clear and retest..
varindasen4002
07-24-2013 03:17 AM
un1ko
03-09-2012 08:41 AM
SlickMachine
02-01-2012 05:09 PM
yellow_submarine
07-25-2011 02:24 PM
kibs45
12-08-2007 11:52 AM
Quick Reply: S4 issues.... never ending
