s4 bucks really bad
s4 bucks really bad
2000 s4 6speed when I'm driving the car no matter what gear I'm in right around 3k rpms it bucks me like the engine sputters
any ideas but only when I accelerate quickley if I gradually push the gas it doesn't do it I emptied the tank and filled with premium feul and some dry gas and fuel injector cleaner too I'm at a loss and I just bought it little pissed
RE: s4 bucks really bad
doubtful its the fuel injections (in my opinion). id go with AudimitriS4 on this one and say its probably one of your coil packs....a lack of fuel, unless its all injectors, shouldnt cause a noticable shudder....however, one bad coil pack can.
I was showing off my S to a friend once and under full throttle at about 3000rpm's the power would just drop off then pick up about 100 rpm's later just as strong. It happened maybe 3 or 4 times in a row and now i havent experienced it in over a year
if it only bucks when you give it boost but not under normal light driving, it's an ignition issue and not fuel.
The car when building boost also advances the timing, you probably have a worn plug(s) or bad coil pack(s). I bet it's getting spark blowout. I'd change all 6 plugs first since those are cheaper than the coil packs. Then if it still does it you can test the resistance in the coil packs and see if one or more is out of spec and then replace them.
Are you getting a check engine light? If so check the code it will tell you which cylinder is misfiring and then you know what coil to look at after you change the plugs.
05A4USP
12-29-2011 10:33 AM
