Radiator - How to get to the Drain Plug?
RE: Radiator - How to get to the Drain Plug?
Thanks 2k S4! Do I have to twist the rad hose? I see that there is a sensor. My question is, do I have to twist that plastic part (after removing the metal pin) before trying to pull the hose? This thing is like glued in there... (just like the pinch bolt on the upper right)
ORIGINAL: to3o
Sometimes they get caked on there you can also gently take a very skinny flat head screw driver and stick it in and circle around the hose and then give it a little pull. This always works for me.
