Quick MBC question.. I want it installed tonite!
i just got the vast tdc and forgembc and was wondering which way i should install the mbc. should i run it inplace of the j valve, but keep the j valve plugged into the harness w/ capped off ends to prevent cel? or should i run it in parallel with the j valve, which i have no idea how to do.
let me know so i can have it in tonite!
RE: Quick MBC question.. I want it installed tonite!
sry i was wroking on my friends jetta all day.. i meant to say n75.
i put the mbc in today but there was no change? i feel it runs the same with the n75?
ORIGINAL: S4evr
You need to set it up when running Vag logs on block 115.
If you want it to control boost, then you need to take the N75 our of the vacuum circuit, but leave it plugged in.
Really the MBC is more for K04 cars, then K03 cars.
