puching cats.
puching cats.
If I punch cats on my 2000 s4 will i throw codes? If so what can i do to avoid this?
I pretty sure i read somewhere that an aftermarket chip will ignore this but not sure wherei read it now.
Does anyone else have a tough time with this sites "search" option? cant seemto get any results out of it.
RE: puching cats.
ORIGINAL: sweeds4
Vast CELimiators.
Vast CELimiators.
Also, will this method also work for the rear cat?
RE: puching cats.
I just did the piggie pipes and they were a PITA. But to answer your question, you canget the eliminators or relocate the O2's. Also since your already putting holes in the cats you should just take them out completly. Its hard work but pays off at the end when your making boost the second you touch the gas. Also you can hear the turbos a lot more
RE: puching cats.
Relocating them is the better way. The car is better off with the info from the o2 sensors for air mixture and fuel mixture and good running order and all that. You get like a few hp doing it, butthe real trade off is instant spool for the turbos. Oh and its the rear ones you relocate and would getthe eliminators for you don't touch the front.
RE: puching cats.
First post... Hi everyone.
Do the rear O2 sensors actually relay information to the PCM for fuel mixture purpouse. Or are they there simply to enforce that the converters are working as they should. ie... the pre converter 02's take the readings for fuel mixture, the rear 02's just ensure that the converters are doing what they should, based on the difference in value read by the 02 sensor itself.
Mike
Mike
