Plz Help! Where is this VAG Connector?
Hi Guys!
I have a Blitz Dual Turbo Timer in my ´00 S4 B5MT
I have already installed the TTand connected the harness. The only thing is, i can´t connectthe ignition cable, because i can´t find the VAGconnector (see on the picture).
I need to tap the black w/blue cable (ignition)
Please Heeeeeeeeeeeelp!
Thank you guys!
[IMG]local://upfiles/42162/2017A236687E47B5BDF6427C8EA4A87C.jpg[/IMG]
Thank you guys!
RE: Plz Help! Where is this VAG Connector?
I´ve got it. Thank you.
TT works.
But there is another problem.
I can not lock the car while the engine is running. I tried to do the alarm fix, i mean the trick with the black w blue cable on position #6 in the fuse box.
Then i could lock the car while it was running, but the heating, the power windows and the turn signals didn´t work anymore.
Anyone know what to do?
TT works.
Wow, that’s weird. I installed my Blitz tt a while back & I didn’t run into those problems. Check all your connections, before & after you installed the timer. One thing I ran into, my central locking system has stopped working and I don’t know if it’s related to the timer or if the pump just went died on me. I posted this question once before & some members pointed to the timer as the culprit. I’m about to just eliminate the timer all together just to see if the central locking comes back on line.
