pig pipes
pig pipes
I finally got around to "start" doing them, and let me tell you it wasnt fun getting the suckers out. But i got all the poopy cat out of the DP's then tomorrow im getting the bungs welded in for the relocation of the O2. What should i be expecting when i get them in. Shes all stock except the piggies.
RE: pig pipes
What should you expect as in what? power? noise? Those will be increased. Try looking into custom catback as its probably not that expensive. single 3" with 1 muffler should be a couple hundred bucks. that will reall help the breathing out a lot. Good job with the dp's! I hear that cat stuff is nasty!
RE: pig pipes
your stock except for your dp's, you are really not useing the dps with a catback wont help to much. your spool up time will be lower but you will have a hold up with the rest of your exhaust. good upgrade to do, you will jsut want more and more when you feel what you could get out of it.
mrbillmartin
04-01-2014 09:43 AM
jakgtrey
05-20-2008 11:02 PM
