New audi urs4 owner with some questions !
Old 10-15-2009 | 07:49 PM
popi-dude's Avatar
Default New audi urs4 owner with some questions !
Hey there audi anthusiasts. I'm a new audi urs4 owner from Canada.
I love this car so far. But there is few trouble with the car since i only
paid 3500 $ cdn. It only haves 150 000 miles on it !
Brakes are dead must replace disc/pads
a seal from the diff is leaking
it needs new winter tires
The body is in "ok" shape but not perfect.
There is also a minor leak of power steering liquid from pump.
last thing is air in the brake lines.
This may looks like a big problem list but i'm willing to do what must be done to make her in good shape !
here are some pictures.
I have a few questions tho... How does the clutch pedal is suposed to feel ?
I feel like my clutch pedal have a very small throw... I stall 1 times out of 4 at signal lights...
thank you for your interest !
and sory for my bad english !
Old 10-15-2009 | 08:27 PM
drobrt's Avatar
Pretty sure that its just in Audi's nature to have a short throw. I've had my car for two years now and still can't 1st to 2nd perfectly if I'm driving casually.
I love your car, I wish I could find a good deal on an UrS4. I would rock that thing for the winter. I love the inline 5 turbo. So if anyone knows of an older Audi for sale let me know!
Old 10-15-2009 | 08:36 PM
popi-dude's Avatar
they are even more rare here in canada...
the throw of this clutch pedal is really short i hope i'll get used to it soon...
also the ! Brake ! Light is always on... But the emergency brake is not on.
Any ideas ? well i dont think it is on the handbrake arm is in lower position and it moves freely.
Old 10-15-2009 | 09:15 PM
derek072887's Avatar
the clutch and brake fluid system share the same resivor (spelled wrong), so if the brake lines have air in them its a good chance the clutch line may also. I would get those bleed out and let us know if that helps with the clutch situation.
Old 10-15-2009 | 09:49 PM
popi-dude's Avatar
thank you for the info !
i'll take a look at it monday or tuesday.
I'll be putting on new brakes also !
i gotta take some better pictures of the car also
Old 10-15-2009 | 09:55 PM
RED_01's Avatar
Slap some pads and rotors on that thing and bleed the brake lines.
Hopefully you know how to do a conventional bleed and your abs pump hasn't gone dry.
If the system has excessive air in it an/or the ABS module is not working properly due to low fluid / excessive air use this procedure...
With these systems, the correct way to bleed the ENTIRE vehicle is to use a VAG-COM that allows you to cycle the ABS valves and/or the pump motor WHILE you are bleeding the brakes. In effect, this allows you to open the hidden passages in order to purge the fluid completely. Fresh fluid is then drawn into the ABS unit, and the old stuff can be flushed away with the air. Nothing to it.
The end result takes a little more time than a conventional bleed, and requires you use a little more fluid, but looks like this:
Step 1 - Manually bleed RR, LR, RF, LF brakes
Step 2 - Install VAG-COM and cycle all valves and/or pumps
Step 3 - Manually bleed RR, LR, RF, and LF brakes again
You end up having bled the system twice, but this is necessary to ensure that fluid - and not air- is drawn into the unit the next time that the ABS valves (and/or pump) are cycled.
If you have access to a VAG tool and need to know the bleed procedure for the tool I can PM you the instructions.
Good Luck !
Old 10-15-2009 | 10:51 PM
popi-dude's Avatar
my ABS light is turned on already...
so i bet i will have to use this procedure.
I only have basics knowledge in mechanic.
But my friend have 2 audi's 90 and 1 audi s4.
I'm going to do this job with him. I will ask him
about this procedure and see what happens
Old 10-15-2009 | 11:58 PM
RED_01's Avatar
Sound good! Let us know how it goes!
That's a huge wastegate BTW!
Old 11-20-2009 | 04:46 PM
popi-dude's Avatar
hey there !
i slapped some new pads in there and changed the discs. I also bled the clutch lines and the break lines !
Everything is fine now !
1 thing tho... I noticed that the car wont drive straight... It needs an alignment badly lol. The front tires are worn iregulary. I also need some new bushings. But the car is now driveable
Hope we get a lot of snow this winter so i can have fun with Quattro
Old 11-20-2009 | 07:11 PM
Audi_Skydiver's Avatar
Can i have that engine PLEASE?????? Thanks. Ill PM you my address...
Nice car dude! I wouldn't mind one of those. They are sweet and I LOVE the I5T!
josh
Quick Reply: New audi urs4 owner with some questions !
