MTM chipped ecu installed.....codes?
Old 02-07-2008 | 10:03 PM
Blackjak's Avatar
Default MTM chipped ecu installed.....codes?
[align=right]edit delete [/align] Ok, just bought a chipped MTM ECU from someone here on audiworld and I installed it today, I let it calibrate etc, took it out for a spin, I noticed it, but i also noticed that my car somewhat stumbles now as if its having problems getting up and going around 2500 rpm only in like 3rd or so but when it hits 3000+ the chip kicks in and you can tell so I have no idea whats going on here, my check engine light also went on after like an hour or so of driving with the chip,
Heres the codes.
P0442
EVAP Emission Control System Leak (small)
P1130
Manufacturer Control Fuel Air Metering
DTC Description
Long Term Fuel Trim mult.,Bank2 System too Lean
P1128
DTC Description
Long Term Fuel Trim mult.,Bank1 System too Lean
lol for the love of god someone help me Im freaking out
Old 02-07-2008 | 10:22 PM
deephouse's Avatar
Default RE: MTM chipped ecu installed.....codes?
What year is your S?
Exactly what other mods are you running?
Let's start with that info....
Old 02-07-2008 | 10:27 PM
deephouse's Avatar
One problem with buying a chip from a person out of state:
IN cali we only get 91 Oct.
In other states it might be as high as 93.
I actually have a friend that bought an ECU out of state and it ran like ****.
SO another bit of info that could help us answer your Q:
What state are YOU in? and What state did you buy your ECU from? It could be programmed for a higher octane.
I have a Bob Pastore MTM 1+ clone in my UrS4 and I specifically told him to program it with 91 octane in mind. Car runs smooth like butter.
This might be your issue....assuming nothing else has changed but the ECU...
Old 02-08-2008 | 01:10 AM
Blackjak's Avatar
Its a 2000 s4 manual 6 spd. No other mods and the chip is from south carolina im preety sure and i fill her up with 91 octane and I dont see how that would be the problem if I am only seeing this in around 3rd gear btwn 2000 and 3000 rpms, 1st and 2nd are smooth as butter and everything was fine until i got the mtm chip in there, then i got the codes, but im going switch the stock ecu back in and see if that fixs it , if not its probly something the chip did did to my car maybe ruined the MAF maybe it was on its last leg or something dunno?
Old 02-08-2008 | 02:08 PM
deephouse's Avatar
Only in 3rd gear?
So, what does it do under boost, in other gears? is it fine?
Odd.
Old 02-08-2008 | 02:10 PM
deephouse's Avatar
Any difference with the engine being cold vs. fully warm?
AudiA8driver
03-17-2014 09:54 PM
Munzter
07-16-2009 02:52 PM
fumoazul99
07-19-2008 08:15 PM
onepoint8tee
11-16-2005 04:23 AM
