Major Puddle
Major Puddle
I was driving home late last night from the airport...raining pretty good, visability not so good. Cruising at around 60mph and switch lanes to pass a slower car....and hit a mammoth puddle of water...I was kind of boxed in with a car to my right and nowhere to go.
So my two left side tires go straight into it....water goes flying over the top of the car...I was amazed at how stable the car was...not sure if the esp kicked in our not, or if it was the quattro...but the car stayed completely straight, online with no steering torque (I've owned allot of front drive cars, and diving into a big puddle like that can be an adventure!!).
Anyway, this was the first time I've had the awd in conditions where it was really needed...and I was really happy with the results.
It also looks like there might have been some crap in that puddle too, cause the plastice skid gaurd just behind the front left wheel got shreded, with some peices dangling around. I has been raining so much that I have not had a chance to check under the car to see if there is any more damage...hope not.
RE: Major Puddle
I was thinking blown engine too when I read the title.
Its not that strange of a way to blow an engine, its just that water gets pulled up the intake enough that when the engine hits the compression stroke, the piston tries to compress the water. Liquids do not generally compress, and thus the energy created from the other pistons has to go somewhere. The connecting rod is the weakest link in the system and it breaks, ravaging the inside of the block and/or cracking it.
RE: Major Puddle
ORIGINAL: Cameron
RE: Major Puddle
ORIGINAL: abacab
Thanks for the explanation....that is just brutal....luckily it was not deeper than it was!!
ORIGINAL: Cameron
RE: Major Puddle
ORIGINAL: dankhound
It takes more than a puddle to blow a motor. Unless you consider a foot or more of water a puddle.
