LuK Clutch? Ever Heard of it?
http://www.amazon.com/00-04-Audi-S4-...833930&sr=1-51
Anyone ever heard of this? I want to get a new clutch while they have the engine out, and thats cheap as hell.. Worth it? Has anyone ever even heard of LuK? I havent, maybe yall that have been around Audi's for a while have..? Input/Feedback? THANKS!'
http://www.amazon.com/Original-Quali...34430&sr=1-431
or this one?
or this one?
I'm pretty sure it's the OEM standard clutch. I know when I upgraded to a RS4 clutch from esctuning.com ecstuning.com it was a LuK clutch. I have had no problems of any kind since install 3 months ago.
hey mys4.org.. how much did yours run you? what stage did you buy? what other modifications did you have to do to put it in, is it a direct bolt on or did you have to buy the flywheel also? anything else that should be bought when buying the RS4 clutch?
Here the thing if you can find a place that will resurface the stock flywheel then cool. Our flywheels are not the typical setup so not a lot of places can do it... Just do your research. I had to buy new one because I could not find a place that could do it for me.
The RS4 kit I got at http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T was about $500 if I remember correctly. Looks like the are cheaper now. Everything that you need comes with this kit which is awesome. I'm wishing I got the Lighten flywheel but oh well. I believe the OEM flywheel is $500 which I got from http://shop.achtuning.com/index.asp?...ROD&ProdID=851 but if you want to spend a few hundred more I would get a lighten flywheel at http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
Simply put everything is a direct bolt-on. I hope all of that helps.
