Loss of power, wierd turbo noise at 2rpm's?
I was driving and guned it and the turbo made a noise and lost power. Its seems as if the turbo went im not sure.At 2 rpms when its suppose to spull it makes a noise. How much is it to replace turbo's with the drop of the engine?
RE: Loss of power, wierd turbo noise at 2rpm's?
If it still spools then you havent blown up a turbo, could maybebe an oil leak if theres a grinding noise. Take it to the dealer if it still under warranty.
With my past experience on trucks limp mode throws a code in the ecu because the clutch slipped when accelerating with the turbos spooled, I'm guessing you have a tip. In limp mode it keeps the tranny in a certain gear until the code is cleared. Correct me if I'm wrong but this what I know limp mode as. If this is the same with audis, build up the tranny to avoid limping it or take some power out of the tune.
This is probably way off what Audi's limp mode is [&:]
