Looking for Relocation kit for Aux. water pump/DIY without removing manifold?
Old 04-05-2010 | 09:06 PM
DraxeofDclan's Avatar
Question Looking for Relocation kit for Aux. water pump/DIY without removing manifold?
Anyone sell it? Can the hoses be fitted without removing the manifold?
Old 04-12-2010 | 11:45 PM
drev500@aol.com's Avatar
I'm almost positive it can not be done without the intake mani being removed.
Old 05-06-2013 | 11:19 PM
Zachariah's Avatar
It's very possible, without removing the intake manifold. You just have to be prepared with ALL the right tools and replacement parts:
TOOLS:
~Long flat screwdriver
~Long needle nose pliers with 90deg bent tips(KEY)
~Allen hex bits(for removing SAI unit, from Tiptronic A6/allroads)
PARTS:
~Bosch Auxiliary Water Pump #0392 020 073
~Inlet "L" hose #078 121 082H
~Outlet "V" hose #078 122 349
~Four replacement worm-drive hose clamps
METHOD:
~Remove SAI with 5mm Allen bit and 10mm bolt behind unit(Auto only)
~Move coolant tank over towards driver side shock tower
~Remove all spider hoses going into Combi valves(Auto only)
~Remove intake "Y" pipe and accordian hose
~Remove driver side Diverter Valve
~Unplug blue two-prong connector from pump(Behind/under center intake)
~Using bent needle nose pliers - pinch the front hose spring clamp, slide back) and use pliers to wriggle hose from bleed screw pipe
~Use bent pliers to loosen rear hose(inlet), just under steel turbo feed line
~Use long screwdriver to push pump assembly back 1/4" to release from round rubber mounting grommets
~GENTLY slide pump assembly(with two hoses intact) out the rear of engine
~With new pump and hoses attached - install in reverse of removal
ETA: Allocate 1-3hours
BENEFITS:
1) No Throttle body adaptation necessary, if intake manifold is NOT removed
2) No threat or dropping loose objects inside intake
3) No potential for pinched wire/vacuum connections
4) No loss of fuel pressure, since fuel rail is untouched
5) No gaskets to buy/install
6) Less removal of parts
Old 05-07-2013 | 09:29 PM
FonzoB5S4's Avatar
nice write-up. never done it without removing everything!
kit:
Apikol 2.7tt Coolant Afterrun Pump Relocation Kit
034 sells a delete kit. relocation is a better option in my opinion.
Expplucky
04-24-2013 03:11 PM
prsalmon
05-31-2011 06:29 PM
02AudiA63L_65
08-21-2010 10:57 AM
DraxeofDclan
08-02-2010 08:20 PM
lehighwiz
06-01-2007 09:52 AM
Quick Reply: Looking for Relocation kit for Aux. water pump/DIY without removing manifold?
