how to order these hid's for my 01 s4
hello all im confuseed as to what bulb anbd color temp to order to get brighter lights then my strock but also not blinding lights. so this kit i can order any temp i want but i do not know what type of bulb i tell them it is ...heres the link can someone tell me what bulb i should tel lthem i need???
http://cgi.ebay.com/ebaymotors/H1-H3...spagenameZWDVW
RE: how to order these hid's for my 01 s4
well our stock light temp is 4300k so I see they sell a 5k, 6k, 8k to upgrade to 5k would be pointless anything higher than 8k or so I think is illegal. so the 6 or 8 in diamond white cause the blue and violent tints are also illegaland I'm not sure how these lights work or if the name is reliable though.
5k is not pointless since it eliminates ALL yellow spectrum as opposed to the 4300 at the same time delivering a pure white/light blue light as opposed to 6000k and above which range from blue to purple. Also as you climb higher in temp you lose brightness. I would stay away from any no name brand lights. I have gone through a lot of them and they are not worth it. They do not last a long time and lose brightness faster then good brands.
Order phillips D2S 5000K from ebay. They are 98 new and are amazing. I assume you have stock xenons.
Here is the link of the bulbs that I got when my OEMs burned out.
http://cgi.ebay.com/ebaymotors/NEW-5...spagenameZWDVW
ok i understand what you guys are saying but when i order these lights do i order the h1,h2,h3 or 9004,9005 what bulbs are the ones to get??? im definitely gonna try these lights out seeing how my stocks suck at night and i am broke so im guna try them and hey they coem with a 2 year warranty so its worth a shot..so what kind of bulbs do i get??
I believe they are H7. I'm not 100% sure though. If you go to the Sylvania website you can input your car make and model and it will tell you every single bulb type possible in your car. So check that out before ordering.
the headlights are D2S/D2R while the foglights are H7; however i knew that people could mod the H7 HID works with D2S base somehow you will need to dremel the plastic piece a little to fit in.
Hey mattr7786, how did you install your DVD unit. Did you custom fabricate a piece that fits in place of the radio? What did you use to make it look like the surrounding plastic pieces? I would have sent you a PM but your profile was off.
ORIGINAL: drobrt
ORIGINAL: ahwest
this is from sylvania's website..
2001 AUDI S4 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
H7LL Long Life Halogen: Lasts two and a half times longer
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
2827
3457ALL
Rear turn signal
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7528
High mount stop light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H7
License plate
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7506
Front sidemarker
3457ALL
Rear sidemarker
2825
Glove box
6418
Map light
64111
Dome light
6411
Step/Courtesy light
2825
6418
Trunk/Cargo area
6418
Under hood light
6411
[/align]
__________________________________________________ __
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
