How long it will take to change engine mounts on B5 S4 ?
When i was installing my piggy pipes, i noticed a bad engine mounts on the pass side.
After taking a look at it, space around the mount is more than limited (particulary for the top
bolt). How much time it will take to change mounts ??? I've just ordered RS4 mounts and should
get them in a week or two. Does somebody knows the procedure to get them in/out ???
Thanks for your help
RE: How long it will take to change engine mounts on B5 S4 ?
Have to put in "service mode" and drop the cradle while supporting engine from above. probably the easiest way i know how to do it, unless someone else has another method. probably about 4-6 hours if youve never done it before.
To expand on what Coop said, it's a lot of work.
So I would not do it unless you are doing a TB, or other front end work that you need to remove
the front clip for.
Don't forget the Snub mount.
the front clip for.
Hay guys ware do u get u genuine RS4 mount from apart from the dealer, coz i remmember one of the online vendors a wile ago was suppling them and they werent the genuine RS4 ones?Cant remmember which vendor it was again [:@]
2k, it got the DTS, if i use the snub as well wont it makit to stiff, coz i thought u need a little bit of flex some ware, and some of the guys are saying if u got the DTS dont go the snub?
ORIGINAL: MICHAELMARC
The DTS is more for the trans, & drive shaft. It keeps it all straight allowing more torque to get to the wheels. the snub helps keep the engine from torquing.
If anything I think having both the snub & dts will help the engine mounts last longer, and should take some shock off the drivetrain.
I have not noticed any more vibration or harshness from having both. The DTS really helped stiffen up the front end on my Tip. The car handled a lot better after the install.
Thankx 4 ur help
ORIGINAL: chebert69
Wow ! Another week end working on that car . I will have too wait a little cuse my wife will F*&?kill me[&:] I already spent 2 days on the Piggy pipes during my Xmas vacations.
Thankx 4 ur help
Thankx 4 ur help
o0hmikee
06-18-2013 03:01 PM
madridlover
01-13-2009 05:28 PM
