help w/ cv repair
help w/ cv repair
I was hoping someone could tell me if the bolt holding the upper control arms threads out of the pinch joint or if it is just pushed in. i got the nut off no problem but the bolt has no interest in moving. soaked in pb blaster for a day. everything else is done i just need to pop out the upper control arms from the pinch joint. any help is greatly appreciated.
that and the pinch bolt can be a real bitch to remove. I've spent LOTS of time removing those ******** on 2 S4s now. It'll come out, just keep working at it. The bolt needs to be replaced if it's giving you that much trouble, put in a new one. Also, apply some anti-seize grease when you bolt it back up. Not sure if it helps since I haven't had a need to remove mine since applying the grease, but it can't hurt.
thanks guys. i have already gotten two new bolts seeing as though i still need to do the other side. i have deformed the bolt in question already so just waiting to have the time to go back out ot the garage. just gotta get it to move then i will cut the end off with the sawzall. fortunately it is winter and salty so im not in too much of a rush.
