Hard to start in morning. Please read
Old 01-25-2012 | 10:59 AM
sleshnyc's Avatar
Default Hard to start in morning. Please read
So every morning when i go out to my 2006 S4 I have to turn the key several times to get it to 'catch'. it's not that the engine is turning and won't start. it's as if the starter/ignition isn't being triggered. it's getting worse. but after that one time, the rest of the day the car starts right up. any thoughts?
Old 02-01-2012 | 01:10 AM
srlito's Avatar
My 04 does the same thing in the morning sometimes. mostly if i don't start it for a day or so. I have the 6spd so im not exactly sure what your problem is. My remedy is to try to start it a few times, stop trying for a couple minutes and then it starts right up.
Old 02-03-2012 | 03:10 AM
JETSPEED333's Avatar
SoCal Crew Member
bad contact in the ignition switch?
Old 03-29-2012 | 03:24 PM
biker921's Avatar
I'm also having this problem. I bought my 2004 S4 a couple of weeks ago and it seems that if it sits for 6+ hrs, it takes a while to attempt to start. I know the previous owner replaced the clutch and flywheel about 700 miles ago. Could it have anything to do with the wiring to the ECU reading the clutch being pressed is loose?
Old 03-29-2012 | 08:33 PM
M5S5's Avatar
Tech Certified
Agreed with Jetspeed , sounds like a ignition switch contact.
Old 03-29-2012 | 09:01 PM
aaroncar's Avatar
Mt A4 has the same problem,I had use a diagnostic tool MemoScan VAG5053 to read the fault code but no code show.So I do not know what reason cause the problem.
Old 04-02-2012 | 11:42 AM
biker921's Avatar
Makes sense, last night (after sitting for 18 hrs at work) I went to start the car and all I got was the familiar "click" that comes from a starter/solenoid problem.
Is the ignition switch a quick fix, easy to find, and/or easy to replace?
bam2008
B7 Models
16
05-17-2010 10:49 PM
krattzz
07-22-2009 06:29 PM
TURBO_S2K
05-14-2009 08:33 PM
oklahoma audi
08-07-2007 10:40 AM
MattyAudi
02-12-2007 10:29 AM
Quick Reply: Hard to start in morning. Please read
