giac x vs apr
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
ok im thinking about getting a chip seen some for sale used so
GIAC X tuned for 93oct
or
APR tuned for 93oct
so what are every ones feelings on the 2 chips
i think the giac x makes a small amount more power is this true anyone tryed them both out ?
or
APR tuned for 93oct
ORIGINAL: 2k S4
Either one is fine, just make sure if you buy a Used ECU, that you can use it in your car.
M or T box, you can use an older one with a cluster re-code, but dont waste your time, older cars usually do it so they can use a M-box.
M-Box will probably be the easiest and most availible one out there. I know there are plenty of used Giac-X m-box's out there for liek $525-600 in the classifieds, thats pretty good if your already in the market for a ECU, seeing as how the Stealer wants $1100 hahahah
Giac X.
You can't run an mbc with APR and if you want the most gains, you will get GiacX with an MBC+TCD and set your boost to 19psi
either way a giac x car will beat out an apr car anyday of the week
ORIGINAL: Deb38
Giac X.
Giac X.
![Big Grin](https://www.audiforums.com/forum/images/smilies/biggrin.gif)
mikekehler
10-06-2009 12:38 AM
