Fastest S4? or bomb?
What's up everyone? I'm new to this forum, and not really a technical guy with cars... but over the lastcouple weeks I read A LOT about the b5 models... before getting into the modification craze, I recently bought a 1997 2.8L 12valve... first mistake... now, I'm thinking I'd like an S4. I want to mod it like crazy, but don't want to make the same mistake I did with the 2.8.
I want to know how fast and reliable a super modified S4 can go onstreet tires and pump gas. From what I've read, doesn't look like an S4 can break 11 seconds... doesn't look like it traps more than 120~ish. Is that about right? Are there any better?
Ideally, I'd like RS6 turbos, rs4 internals. As for tuning, who's the best? Not best deal, but best period. What does something like that run- trap speed and 1/4 time? Is it reliable? How much will it cost?
One more thing... has anyone ever sequential turbo charged an S4? Is it even possible? For example, either K04 turbos or RS6 turbos in the engine compartment, and a larger rear mounted turbo in the back? Is that crazy or feasible?
Lastly, how much would something like that cost including installation and tuning? (RS6 turbos, RS4 internals, tuning, sequential turbos)...
I dream of having a 10sec S4...any input isappreciated
RE: Fastest S4? or bomb?
ORIGINAL: a4audia4
What's up everyone? I'm new to this forum, and not really a technical guy with cars... but over the last couple weeks I read A LOT about the b5 models... before getting into the modification craze, I recently bought a 1997 2.8L 12valve... first mistake... now, I'm thinking I'd like an S4. I want to mod it like crazy, but don't want to make the same mistake I did with the 2.8.
I want to know how fast and reliable a super modified S4 can go on street tires and pump gas. From what I've read, doesn't look like an S4 can break 11 seconds... doesn't look like it traps more than 120~ish. Is that about right? Are there any better?
Jaybquick has a k04 car that runs 11.19 at somehting like 130mph and thats pretty damn fast for k04's. 10's on ko4's is pushing it but is possible, yeah on street tires you will have trouble hooking up. Remember though weight reduction can do wonders. However with new turbos and enough money the limits are endless.
i believe the "hybrid turbos" use an rs6 compressor wheel in a modified k04 housing, definitly 100% not rs4 internals. When comparing a k04 kit to the rs6's its going to be SIGNIFICANTLY more expensive for hybrids. Its still in the process of being developed so its probably not as relyable and proven as k04's YET. "best" is a difficult term... i get work on my car done locally because its easier, but if i was going to be spending the equivalent of a years touition tuning my car i would send it to VAST. If your serious about it and have the money to fund it im sure they would work with you to make a 10 second car. They have a great reputation.
I think its a daft idea. There are multiple methods of turbo charging, staged and sequential are far more complex than parallel. Id Just go with 2 new turbos, if you want power that badly go for bigger turbos, something like Garrett GT28r's
Id say no less than $20,000, and it could end up being more. Theres ALOT you would have to replace, full exhaust, intercoolers, clutch, youd be pushing your transmisison to its limit. With that much power youd want a BBK (youd realize the first time you tryed braking from 150mph), new suspension.... etc
I dream of having a 10sec S4... any input is appreciated
My presonal opinion: tuning an s4 is expensive. The more power you want the more it will cost. k04's will get you close to 10's but are by far the cheapest and easiest path. Weight reduction also dose wonders. If you have the money, go garrett but a k04 car is fast enough imo
As far as cost of a good k04 kit... Id go AWE with fueling for $5500, AWE downpipes for $1700, Exhaust ranges from $700 - $1500, Intercoolers around $1400. Add a new clutch and soem goodies like short shifter, DTS, Engine mounts, DV's, and bi pipe. all before installation...That would be a SOLID k04 car. After that you can add brakes, suspension, lighter wheels, and really theres no limit to the money you could spend....
Murphy boy, I'm right there with you... if I could trade blood for some of those parts I would... SO EXPENSIVE!
Hey, thanks for your input, HP addict. I don't know if I'm alone on this one, but I think a 20,000 investment in a b5s4 is a beautiful investment considering some of the "performance" cars coming out... I love the sleeper look. I really think I might do this. As for just having larger turbos instead of sequentials, Ithought larger turbos have longer lag times... that's why I thought having the K04 or RS6 turbos (or hybrids) for quick response and larger turbos for higher RPM response wouldgive the best performance over a wide band... no? I saw a company that makes rear mount turbos- STS- I wonder if it would work. Is it a terrible idea for some reason that I haven't learned yet? Or is it just too much power for the S4? Or maybe too much heat?... by the way, you mentioned GT28R turbos. How do they compare with RS6 turbos? Or RS6 hybrid turbos? and also, by the way, that last comment of yours (about having no limit to the $ put into the car)after seeing some of the parts costs, I believe you word for word about that... kind of scary though.
I just want to make sure I have all the facts straight before I go investing that much money. Before I buy the car, I want to have everything I want to mod mapped out. Anyone else know about the sequential turbo feasability?
ORIGINAL: a4audia4
That's just my .02. (but with the current exchange rate, it's not worth much)
[/quote]
[/quote]
http://www.youtube.com/watch?v=WPe2Wgg8s08
Nuff said.....
[/quote]
Nuff said.....
How about a 9 sec S4? http://video.google.com/videoplay?docid=3986370630426338539&q=fastest+ s4&total=20&start=0&num=10&so=0&am p;type=search&plindex=1
I'd even use that as a daily driver!
First question you need to ask yourself is how deep your pockets are. If you really want to sink your teeth into this, like said above, take it to VAST. Those guys can set you up with everything you need and install it. For turbos I'd get the GT28 kits, not sure who makes it but I thought it was from VAST. AWE is also a great company to work with. I think the sequential turbos would be kinda pointless, they're more for the larger displacement engines.
You want exhaust to be cold, heat = lose-of-energy = less power which resulted in the invention of the intercooler......
ORIGINAL: Reckless_Kelly
not tomention the fact that as the exhaust cools, it contracts and becomes less efficient
