ever heard this noise???
Old 07-27-2007 | 08:51 PM
JETSPEED333's Avatar
SoCal Crew Member
Default ever heard this noise???
sometimes when i start my car in the morning or after it's been sitting for a while i hear a caka-ling noise(chick-a-chick) right under me.... seems to be coming from around the cat's.... i put my car on the lift here at work and checked every inch and banged on just about every part with a rubber mallet....... nothing... no sighns of where the noise could be comming from....
when i drive the car, everything is perfect... no odd noises, engine sounds perfect, no rattles... i am maybe thinking this could still be a problem with the catalitic converters? the noise, when i do hear it only last for a split second and it's gone....always on initial start up... any ideas of what this is??? .... i wonder if i could get a sound clip of it
Old 07-27-2007 | 08:54 PM
TKneedsS4's Avatar
Default RE: ever heard this noise???
dont most cars make that noise? like first few drops of oil in the catch can or something idk what the noise is but i hear it on plenty of cars.
Old 07-27-2007 | 09:00 PM
SoCal Crew Member
i don't like it and don't belive it should be there..... sounds like something is loose and takes away from the awsome start up sound the engine/exhaust makes
Old 07-28-2007 | 02:09 AM
SoCal Crew Member
how about a motor mount?...
Old 07-28-2007 | 12:19 PM
SoCal Crew Member
i am leaning towards a motor mount now becasue sometimes when i turn off the car i hear the noise too[:'(]
Old 07-31-2007 | 06:42 PM
SoCal Crew Member
bump
Old 07-31-2007 | 06:46 PM
2k S4's Avatar
Loose heat shield?
Old 07-31-2007 | 06:59 PM
SoCal Crew Member
i would hope so.... what's weird is after the car has reached normal opp temp. and i turn it off... when i re-start the car i do not hear the noise.... usually only when it's cold..... i guess i will have to put the car on the lift again to check up in the engine compartment for shields.....
can the gas motor mounts make noise like this???
darawilliams
03-04-2011 05:29 PM
a4vt1.8t
05-27-2010 02:05 PM
CoBra03TerminAtoR
04-25-2008 02:51 PM
Figgy1682
12-27-2007 04:01 AM
Dj Spiel
02-26-2006 10:09 PM
