EPC light turned on today... GRR
Today my EPC light turned on. I checked codes and this is what came up:
2 Faults Found:
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-00 - -
I cleared them and the P1676 code came back immediately. Is this a throttle position sensor? Or what is it and how do I fix it? Thanks.
Josh
P.S. THe car runs perfect still. Nothing noticeably different performance wise.
2 Faults Found:
P1676 - 35-00 - -
Josh
RE: EPC light turned on today... GRR
I had three codes pulled:
18098 - Malfunction Indicator Lamp (MIL) -K83-
Electrical Malfuntion in the electrical circuit, sporadic
18084 - Drive by Wire-MIL circuit
Electrical Malfunction in the electrical circuit
17963 - Value above maximum charge pressure, sporadic
The dealership told me the last one was most likely caused by a leak somewhere. I just pressure tested the car last week and did not find any leaks though.
ORIGINAL: b5hobsons4
18084/ P1676 = ETS warning lamp - circuit malfunction, possible faults are instrumentation control module trouble code(s) stored, wiring problem, matching resistor in the ECM and that would need a good diagnostic tool to test that
I am pushing 18 pounds of boost. I did not know my car was chipped until after 6 months of owning the car and looking under the hood and stumling across the ECU that said OCT Tuning on it. The car seems to let the boost go under hard acceleration sometimes. I did not do this when I bought the car. It will just jerk and there will be no boost. The car seems to run on just the motor. I'm going to invest in a set of 007 DV's. Do you think I should look into somethin else first. I do need a boost gauge. I just found out that I was pushin that much boost last week... any thoughts?
I would checkyour TBB first for any rips then check the DV's. I had my DV's go out about three months ago and had to have the DV's replaced. It would start to build boost and then nada just engine....
