Emissions :(
Old 08-17-2010 | 03:41 AM
betes's Avatar
Default Emissions :(
Anyone got an ideas of passing emissions i failed it twice..... have no cats but my o2 sensors read ok and they have been ok since last year when i did pass....so in other words got any tricks to "eliminate my o2 sensors" so i can pass? im in missouri by the way and have an 00 s4
Old 08-17-2010 | 08:14 PM
meatbiscuit's Avatar
lol, dude, not having cats is a pretty sure way to fail emissions. Surprised they even let you attempt it...usually they take a mirror and look underneath the car to make sure your CATs and O2s are in order.
That sleeve they put over the exhaust -- it's measuring emissions. You're not getting past that part unless you sleep with the crusty old chick running the emissions station or you install a pair of CATs.
Yes, they also plug into the OBD-2 port...that part you can fool by soldering a diode into the (+) voltage line from each of the downstream O2s. Thus, you can get rid of the CEL that comes up as a result of ripping out your pre-cats. (Disclaimer: doing this is illegal, I don't endorse it. If you get into any legal trouble, I am in no way responsible
Did you scan with your VAG? Are you currently throwing any codes?
Old 08-18-2010 | 10:30 AM
bigern45's Avatar
i think that you can bypass the actual im 240, or what ever gas analysis they do there if all of your readiness codes are set, and you have no codes. i was once a certified missouri technician, certified to do repairs on emission failure cars. (years ago...lol) if you can pass the OBD11 tests, then they will not do a gas analysis, unless it has changed in the last 5 years. or get an address out in warrenton or something, that way you only have to pass safety inspection and not gas... i think its only st.charles county and st.louis county, correct?? that does gas analysis??
Old 08-18-2010 | 12:54 PM
Good to know. I was planning on welding in a pair of CATs for my upcoming smog test. Not sure how they do it in Colorado, but, if I could skate by with only having to *ahem* work on my O2s -- that would be much less expensive.
Any idea how it's done in Denver? How can I find out?
Old 08-18-2010 | 03:35 PM
bigern45's Avatar
Old 09-07-2010 | 04:34 AM
betes's Avatar
I'm in Missouri and the shop I got to knows I don't have cats but when I was on the machine with the obd2 it said It couldn't read o2 sensors. Where is the(+) voltage on the o2 sensor in the wire in the pin etc and where do I get diode from? Thanks for the heads ip oh and Missouri doesn't do gas analysis do you know of a county other than stl that doesn't have the stupid electronic emissions test?
Old 09-07-2010 | 11:32 AM
bigern45's Avatar
they only counties that did the sniffer tests or gas analysis tests where the ones with st. louis, st.charles/st.petersburg, and MAYBE kansas city. thats why i suggested warrenton, or maybe lake st. louis (not sure which county its in)
Old 09-07-2010 | 05:33 PM
go here:
http://www.audiworld.com/tech/eng.html
edit:
Oops, forgot to add -- go to the oxygen sensor modification article
AudiRy05
10-07-2008 06:56 PM
1.84life
04-29-2008 11:49 PM
RIA6
09-14-2007 10:06 AM
dubiousmusic
03-01-2006 10:03 PM
ImAudi
10-29-2005 01:56 PM
