Disabling headlight washers b5
Old 09-13-2009 | 10:00 PM
bps4's Avatar
Default Disabling headlight washers b5
Does anyone have experience disabling the headlight washers and plugging the opening on the reservoir? Are there parts that Audi makes in order to plug the reservoir?
Old 09-14-2009 | 12:18 AM
kiellish's Avatar
Member
there's a plug for the motor on the reservoir (it's the bigger of the two motors for the headlights), i suppose you could unplug the connector and plug the hose.
why do you want to disable the washers?
not sure if audi makes anything...
Old 09-14-2009 | 04:29 PM
bps4's Avatar
I don't have a garage and tools so I want to make whatever I do more of a permanent fix rather than replacing the leaking headlight washer pumps repeatedly.
http://forums.vwvortex.com/zerothread?id=3494108
This is a link for a VW where it's showing that there is a specific part to plug the reservoir if you don't want to use it. It looks like a nice neat fix. Wanted to check if someone had some experience doing something like this on a b5 and might know the part number for the plug that goes into the reservoir.
Old 09-20-2009 | 10:30 PM
69fingers's Avatar
So does anyone know why the headlight washers only sometimes active when you use your windshield cleaning function?
Its kinda embarrasing, everytime I go to show one of my friends the sprayer it doesn't work. Then when Im just haning they activate everytime.
Old 12-18-2011 | 11:22 AM
thekyman's Avatar
your headlights have to be on in order for the washers to kick in
Old 12-18-2011 | 11:26 AM
turbo kraut's Avatar
Tech Guru
way to correctly answer a 3 yr old thread
you get the prize
bertible
01-06-2007 01:29 AM
eth700
12-16-2006 11:43 AM
eth700
12-15-2006 01:25 AM
wood_e
11-10-2006 02:31 PM
Quick Reply: Disabling headlight washers b5
