DarIntake with classic panel filter???
PLEASE, it is possibility to USE DARINTAKE HOLE with K&N panel filter? I have this one...
it is usefull to cut the hole with this filter?
or it is waste of time and i must sell this panel filter and buy new one like this
or both filters have the same effect...
yeah i have the first one you are talking about, I just put my k&n in it and works great. I also have the ign filter with the pipe attached but just like the panel filter better for easy of use. i also run a stage 3 off jsut the panel so no loss of power from that.
Darintake shows increased CFM by a measurable ammount. This is comparable to most other intake options so like it or not it gets more air in your engine and dosnt cost you a thing
Usually people cover the gaping hole(s) with some kind of mesh screen to keep stuff out then put a new K&N or IGT cone filter in the airbox.
Good Pictures
http://public.fotki.com/LI-S4/cars_a...ods/darintake/
Good Pictures
I dont understand everything. What is CFM please?
but at the bottom is not fresh air..... i dont know if is better.
WRC drives on this closed box ...with "blast of wind" i dont know if it is good translate to english, but i hope that you understand me.
I thinking, that the hole at the bottom is not better, better is cone filter and hole has not effect (there's no point in)
At the bottom is not input of fresh intake, isnt it?
Maybe is better for US version i dont know, how many HP do you have your stock S4 B5? (My engine AGB has 195kw-265HP Stock)
I think we only get 250HP stock so maybe the difference isnt quite as large for you.
http://forums.audiworld.com/s4/msgs/1189646.phtml
Thats another good thread.
Basically the top 2 lines on that graph show the grams/ second of air being measured by the MAF. (in america we call it cfm sometimes, cubic feet per minute). You can see that the Darintake had a measureable effect on the ammount of air taken into the engine. More Air + More Fuel = More power
I understand you, the air still comes from inside the cramped engine bay so the benifit may be questionable. Also leaves, snow, dirt, etc just might get kicked up into your airbox.
Someone on AZ posted this, they cut a hole in their headlight and created a ram-air intake straight into the airbox. This is probably the most effective IMO, but you trash a headlight in the proscess and have no high beams
http://www.audizine.com/forum/showth...ram+air+intake
http://forums.audiworld.com/s4/threa....phtml#2804608
I see what you mean
I see what you mean
thanx for explanation.
But I thing that better cubic feet per minute (CFM) is ...because on the graph is stock paper filter vs darintake hole + cone filter... the main reason why is CFM better is only cone filter, not hole, isnt it?
Maybe i am idiot but i still dont understand the hole i thing that filter suck air mainly from this hole...and air from outside is better.
You are one of the most skilled members, you have four intakes i guess, darintake, X1,ect ect...what is the best for normally use? i guess stock airbox and ITG cone filter. Stock input is OK a think
that is the best idea.... fresh air ...not hole at airbox in motor place
I think the increase in g/s is due to both the darintake hole and the cone filter, despite the fact that the darintake hole isnt recieveing cold air. Still i think it does make a difference.
As far as all the intakes on the market, Darintake is a cheap easy DIY stage 1 or 2 mod. The problem is Intakes like the AWE s-flow and ABD big bore havent been proven to work that mcuh better than the darintake especially on stage 1 or 2. And they cost $100-$200
The carbon fiber x-1 is my weakness, just so pretty. This is the one intake i would buy, and only if i was getting a custom stage III tune. Otherwise i cant justify the cost, especially when it might not run right unless your car is tuned for it. It draws cold air in like the stock airbox, but also is supposedto seal against your hood to keep engine heat out and also let cold air in theough the front.
My perfect setup would be the X1 with a CF hood like in the second picture that has a scoop to feed cold air directly into the airbox. It also has a vent to help hot air escape the engine bay.
speedmetal1
04-02-2008 01:23 AM
