cold weather??
cold weather??
2 questions...just wanted to check around here with the fellows who know this car inside and out before a stearlership charges me 150 bucks to joyride my car and then proceed to tell me they dont know whats wrong with it.
1. after a cold start, when i go to accelerate, there is a rediculous hesitation, almost to the point of the car cutting out. I have no CEL on, and no stored codes. the hesitation is really bad. what are some possible causes? once it get going for a few seconds, its fine from then on. i have tried even letting the car warm up for 10 minutes, and it still does this. its only been happening since the cold weather hit a few weeks ago. could the oil weight be wrong maybe?
2. Again, since its been cold, there has been a metallic grinding noise from the engine area. its not constant, and only happens upon spirited acceleration at specific RPM points. I fear its from the turbos, but i had them checked out, and was told there is no shaft play, they could be wrong tho. I was thinking could it be again, wrong oil weight not getting into the turbos? any thoughts at all?
RE: cold weather??
Yeah, unless you dont want to pay them for it. in which case you can have an autoparts store pull the codes and I can tell you what they are with my Vag-com.
You should think about getting one. get it from Ross-tech for like $600 and just put it on a laptop. comes with the plugs and everything.
RE: cold weather??
yea, im planning on getting one, but i am getting a laptop from work in january, so then im going to use that since right now i have only a desktop....
still no ideas on the hesitation and grinding noise?
RE: cold weather??
Engine hesitation is often misfire on certain cylinders, one thing is for sure it will through
a code. VAG it. I had a similar problem 2 years ago and it was EGT sensor on bank 1.
It could also be MAF. But we can spaculate for hours w/o codes.
For the grinding noise, it may be exhaust touching floor somewhere, bad engine/tranny mounts.
Good luck and keep us posted with the codes.
Shell
11-19-2010 03:07 PM
nya4
10-01-2008 06:00 PM
