Clutch Replace
Clutch Replace
So Im pretty sure its time to replace my clutch, I think i'm going to go with a RS4 clutch and aLW flywheel.But my question was does anybody out there have some helpfuladvice and the proper procedures to do the job, I already know its going to be a pain in the ***, but any replies will help thank you.This will be done on a 00 S4.
RE: Clutch Replace
ECS is a good place to get a clutch kit, if you looking for a higher quality clutch then check out southbend clutch kits at kinetic motorsport or clutchmasters FX series clutches.
For install instructions buy a good manual, Bentley being the best.
RE: Clutch Replace
I am doing it(replacing the clutch)currently. Plan on hating the top of the downpipes and the top bolts there along with the heat shields covering them and the bottom two allen head bolts on the bell housing specifically. If I were you I would buy new upgradeddownpipes while you are at it since they come out. Hopefully within a day or two I will have a half-a$$ed do it yourself put together for the clutch since I wasn't on AF the first time I did my RS4 clutch. Has there been a DIY on the S4 clutch yet?
