chirping noise on the passenger side
It's getting cold out now and I've been using my heater a little bit more...
Tonight though, I think I turned my heat up a little higher and stronger than I usually do, went for a drive and whenever I made relatively tight left turns, I heard a faint chirping noise on the passenger side, in the direction of the vents and the right wheel... doesn't sounds like the wheel is screeching....
I did a search and found a couple of solutions... it's either "some fan" or the blower motor.
This link shows how to clean the blower motor: http://www.audiworld.com/tech/elec132.shtml
It's for the A6, though. Is it pretty much the same procedure for an S4?
Has anyone else had this chirping problem? If so, how did you fix it?
**EDIT: Just checked the car... no screws where that link tells me the screws are... help?
