Change of Differential and Transaxle OIL, help...
I use changing plane from web Valvoline. I would like to change Motor oil valvoline 0w-40, differential OIL, and Transaxle OIL...
but How long can I used this oils.... when they wrote that service interval is 30000km, does it mean, that i must only check oil.... or I must change IT!!!
There are materials from VALVOLINE:
Audi
A4, S4
S4 2.7 V6 30V Biturbo quattro (1997-2000)
Engine Capacity 6 liter
Use: Normal
Service intervals:
Change 15000 km / 12 months
SynPower XL-III 5W-30
SynPower MXL 0W-30
SynPower 0W-40
Differential, rear 01H Capacity 1,9 liter
Use: Normal
Service intervals:
Check 30000 km
HP GL-5 80W-90
Transaxle, manual 01E Capacity 3,2 liter
Use: Normal
Service intervals:
Check 30000 km
SynPower TDL 75W-90
Hydraulic brakes/clutch system
Use: Normal
Service intervals:
Change 24 months
Brake & Clutch Fluid DOT 3/4
Power steering
Use: Normal
SynPower Powersteering Fluid
Cooling system Capacity 6 liter
Use: Normal
Coolant Maxlife AF
Coolant AF Extreme
Audi
A4, S4
Use: Normal
Service intervals:
SynPower MXL 0W-30
SynPower 0W-40
Use: Normal
Service intervals:
Check 30000 km
HP GL-5 80W-90
Use: Normal
Service intervals:
Check 30000 km
SynPower TDL 75W-90
Use: Normal
Service intervals:
Change 24 months
Power steering
Use: Normal
Use: Normal
Coolant Maxlife AF
Coolant AF Extreme
Now I work at Valvoline and we use A Gl 5 based gear oil that I am almost certain is not compatiable with our cars. You have to use a GL 4 based fluid. I wish we could use the stuff becuase I get a phat discount but ofcourse I cant.....bullshit
The products they offer to you may be different then what they have here in the States. Over here we only offer GL 5 so check the fluid and see if it is GL 4. I just dont want to see you fill up on the stuff and blow the tranny and diff. Just go to the local valvoline or parts store that offers it and see if it it in fact GL 4. cheers
