car is jerking & slowing down...
Old 06-22-2006, 09:16 PM
i3uddha's Avatar
Site Moderator/Ninja
Default car is jerking & slowing down...
https://www.audiforums.com/m_301039/tm.htm
sorry - I posted in a4 to get more hits...
any ideas?
Old 06-23-2006, 12:51 AM
sooks's Avatar
Default RE: car is jerking & slowing down...
hmm.. i dont know.. sounds like your fuel is getting cut.. bad MAF maybe. like someone said in the a4 forum. get your hands on a vag and see what comes up.
Old 06-23-2006, 03:30 AM
scarzie's Avatar
Sounds like it could be a slipping clutch, watch ur rpms. When mine was going it would slip, then basically drop, so it would jerk and slow down. IDK could be it, but if thats not it VAG it.
Old 06-23-2006, 03:43 AM
sooks's Avatar
i suppose it could be the clutch going.. but i dont think thats so much jerky. Seems like when the clutch goes you give it gas and the engine just kinda revs and slowly tries to catch up...
Old 06-23-2006, 05:00 AM
i3uddha's Avatar
thanks guys...
I dont blv its the clutch...I watched my rpms - & its basically just a quick jerk / stall
when I let off the gas... but it only happens intermittently.. I agree fuel or air - Im thinking Fuel Filter maybe???
well - we'll see what the VAG holds for me - hopefully I can use it this Sun at our GTG. weve got a forum member
generous to bring his VAGCOM to our gtg...
in the meantime....[&o]
Old 06-23-2006, 10:00 AM
chebert69's Avatar
Meaby it's a coil pack going bad ? Or some sensors ? If it's a sensor you'll
see some codes with VAG tool. I dont beleave it's the clutch, you would feel
it slip under power and it's something thas gose gradually, im sure you'll notice
it if it happens.
Good luck !
Post your VAG result so we can help you more.
Old 06-23-2006, 12:27 PM
scarzie's Avatar
oh ok... What i was trying to say before, when my clutch was going, it would all of a sudden be like i pressed my clutch in, and while i was still giving it gas it would rev up real quick, then feel like i dropped the clutch when it caught. It did it so fast could barely avoid it, it sucked to say the least. But since thats not it i dont know what it could be.
Old 06-23-2006, 03:49 PM
ChiTowNS401's Avatar
I had the same symptoms when my TBB busted. Make sure its not ripped, thats IF you still have the stock one on.
Old 06-23-2006, 03:52 PM
don't even worry about it till you get it VAGed you can guess all you like but it wont help codes is what we need
Old 06-23-2006, 05:35 PM
i3uddha's Avatar
ORIGINAL: avant80@2.6
Bottom line - Your right.. your such a guru [:-]
*Chitown - thnkx for the good look - but I've allready switched out to APR bipipe...
so thats not it either.. [&o]
THanks for the support guys... Ill post up the info on Sunday if i can use the VAGCOM
@ our GTG.
original: chebert69
Good luck !
I love my forums - you guys are the BEST ! ! !
Quick Reply: car is jerking & slowing down...
