cam adjuster gasket leak?
Old 11-25-2005 | 07:12 PM
techbod's Avatar
Default RE: cam adjuster gasket leak?
this I don't understand ( how does it leak through the cam cover seal?? ) the adjuster is internal to the cam cover please explain
Old 11-25-2005 | 07:14 PM
techbod's Avatar
I'm not into this engine so very interested
Old 11-25-2005 | 07:16 PM
techbod's Avatar
I still think this is a rocker cover gasket issue
Old 11-25-2005 | 09:22 PM
techbod's Avatar
checked all my files and not happy with the answers so far, its a scam in my view "pictures required" with rocker covers still on showing oil leak and data showing valve timing/pressure loss
Old 11-25-2005 | 11:46 PM
AudiTech04's Avatar
Its not an internal leak like i think your thinking of
It leaks out the back of the gasket
See the adjusters sit on top of the head at the rear there is a gasket between that leaks on to the back of the head
Old 11-26-2005 | 06:22 AM
techbod's Avatar
now I'm getting the picture, correct me if I'm wrong "camshaft end seals" and my thoughts were on the cam chain tensioner
Old 11-26-2005 | 03:15 PM
AudiTech04's Avatar
ORIGINAL: avant80@2.6
Bank 1 has the "end seal" at the front and is the rear on Bank 2 those have also been known to leak but not as much at the tenisor
  #18
Old 11-26-2005 | 05:40 PM
lewishw's Avatar
so what is the verdict? warranteed or not?
  #19
Old 11-26-2005 | 06:56 PM
AudiTech04's Avatar
There are many different aftermarket warranties so it always varies
Plead your case and find out
  #20
Old 11-26-2005 | 07:53 PM
Ted's Avatar
Ted
It should be under warrenty. And the Water leak is prolly still leaking, but it never really looks like it, just that pink crud that builds up around the leak.. The oil leaks are allmost allways coverd under warrenty. Good luck
timmay074
11-18-2009 12:29 AM
twinturbosixer
06-07-2009 12:09 AM
Asianicestyles
07-17-2008 01:26 AM
icanhas4wheeldrift
08-09-2007 11:35 AM
Quick Reply: cam adjuster gasket leak?
