Bad Climate control 2000 S4
my climate control head unit does not respond to any buttons pushed. the screen works and its stuck on low AC, can turn it off or change temps or vents, where can i get a new head unit, also one button lights up when i push it but it doesnt stay lit up untill i let go?
RE: Bad Climate control 2000 S4
This happened to me. Sounds like one of your buttons is stuck in. Take a flat knife or some sort of tool and try to pull all the buttons out untill you find the right one and your unit starts to repond when you press other buttons. If that doesnt work try pushing each button hard. If these dont work then im stumped.
This is a common problem, the buttons get sticky and stay on. What I found works really well is a computer keyboard clean, the spray type. Get yourself a can of that and spray away. It takes a bit of work but it does the job.
Hope this helps!!
Hope this helps!!
lems-v8
03-04-2010 09:43 PM
chattyboy
09-04-2009 02:11 PM
